cutting swing arm bolt
Watson84
anyone have any thought on what i should use to cut the the swing arm bolt in my 916 just wont budge:mad: at all not bother about it getting stuck in the casing as go new one for the contents to go in to was wondering if a multi tool would do the job or a dremel or should i just get a bit for my drill or is it just some old fashioned hack saw and hard graft :mad:
If its like my old S4, did you remove the 2 pinch bolts, sort of hidden in the swing arm? I had taken the nuts off them but they still held the pivot bolt tight, after they were taken out, I could remove / install thepivot by hand
