Cush drive
Preid
One of the cush drive bushes (not sure the technical term for them) has decided to migrate towards the swing arm. Noticed it after riding thirty miles home, coming off the bike and seeing the glitter effect swing arm. :(
I'll upload a photo when I get back to my own laptop. Its a beauty.
Is there a short term fix to get the bike to a garage or a pickup job?
Are you mechanically minded? Drift out the old worn Cush drive n replace with a new one. Easy job really
Whats been worn away by the Cush drive is the eccentric chain adjuster hub
Its a new one im afraid if the teeth on you own one have been worn away
Again if mechanically minded an easy replace job you could do on your own
If you can't manage a home repair job itll b phone a garage time cos if you ride the bike without fixing itll eat into the swing arm eventually
Its a job I believe I could pull off but I neither have the tools or any stands around here. No means of getting the bike to my workshop which is miles away.
Ill call up Albamoto as I know Jim comes out this way now and again plus he's picked up my bike from here before! :D
As mentioned, here's a pic.
I've decided im buying a scooter for commuting at the end of the month. The 748 spends more time in the shop than on the road!
Yup thats familiar lol
No stands needed to get sprocket off but not having the tools is an issue
If you at least changed the Cush drive you could still drive about on it
Hmmm
Since you've said that, I've had a look at a few threads on replacing cush drives and if its a regular occurrence on these bikes its probably worth getting used to doing it myself.
Going to contact Albamoto and see if they have any in stock. I'll take all the tools I'll need from work this Friday and if all goes well i'll be back on the bike by Monday :D
Change the rear sprocket for one which has the small lugs stooping the Cush drives working their way out. Most of the aftermarket good quality ones have this as it was a recognised problem.
Should be "stopping" not stooping, need a spell checker
