Cush drive replacement in progress.
Preid
HOWTO - Cush Drive Replacement 748
Im midway through replacing all the cush drives and so far its not been anything like I expected. I read some stories of the nut being on so tight the bikes had to be taken to a shop and the nuts been taken off with an air gun.
Well as I removed the clip that holds the nut in place, to my surprise the nut moved! Wasnt even on finger tight! Think i'll be checking the other side before I set off tonight. :p
Kinda annoyed that I could of avoided having to haul this beast home in a back pack.
The next issue was getting the chain off. No bother I thought, I'll just find the master link and that'll be that... Endless chain! :mad:
So the two bolts securing the hub were undone and I had to use a screwdriver and a hammer to rotate the hub. Ghetto I know but it done the job. I didnt have to hit hard to rotate it which was nice.
A few taps later and the chains loose enough to slip off the sprocket. Sprocket pulled off easily revealing the extent of the damage. Not to bad, the hub adjustment teeth dont seem to damaged. My main concern is if any of the filings have made their way into the bearings. There are filings EVERYWHERE!
The next part I was dreading was removing the cush drives from the sprocket. I saw some of the ghetto removal devices people had constructed. First part though was getting the nuts off the cush bolt threads.
Hammer cush onto allan key, slap on a socket and start tapping with a hammer. Nut comes off and to my surprise I could just lift the sprocket off the cush drive. Every one of them came out effortlessly. Surely somethings not right there?
The hardest part of all this so far has been getting the old cushes off the allan key. Not exactly a tough job.
I've yet to see how the new ones fit into the sprocket. Need to clean everything first and get as much of these filings off the bike.
Oh and for anyone who's reading this and are intending to do it.
You'll need a 12mm allan key, a decent socket set, a hammer, copious amounts of WD40 applied long before starting the proceedure and maybe a 41mm socket for the main nut.
These to!
I got them off Ebay for £85ish delivered.
Should the new ones sit snugly in the sprocket?
Im still considering slapping on some loctite on them before installing.
Looks like you've done a really good and patient job there,not had an issue with the back end on my 748 YET,but all your above info on what tools to use will certainly come in handy this winter when i think i'll give mine a look at.
Two weeks is the length of time from noticing one was migrating until it started machining down the swing arm. I heard a squealing noise while cornering which should of alerted me to it doing damage but I didnt realise what was going on until I saw all the filings :(
A lot of cleaning later.
There is a type of spacer that can come out. You can see it sitting at the end of the teeth. I blasted as much of the crap away from it with WD40 using the red focused spray gizmo before removing it and doing the same again. I used a thick paint brush to flick off the stubborn filings.
After cleaning as much of it off as I could I copper greased the spacer up and placed it back against the hub.
Cleaned the sprocket.
The new cush drives just slotted in, I wouldnt say they were snug but they sit against the edges of the housing. When I turned the sprocket upsides down half of the cush drives fell out.
Everything bolted back in place.
I put a good dose of leverage on the main nut. Another thing to point out is that there's a second spacer like the one above on the nut to look out for. It sits behind the nut against the sprocket. The circlip that stops the nut falling off if its finger tight has one longer end than the other. The nut has a hole that has to line up with a hole on the axle shaft before this longer end on the circlip will go though/fit. By chance the dose of leverage I put on the nut lined the two holes up beautifully. :) I threw on two tyraps as I usually do with these things. I'll get the bike into the shop for its MOT and get them to retorque everything to spec.
And thats it! Hopefully i'll get a few weeks out the bike before something else go wrong! :D
