Sound like we are living each other's nightmare.
Once all the rubber is out, take a hacksaw blade to the outer ring, but don't cut in line with the centre of the wheel as access is limited if you need to drive it out from the back. Once you have cut most of the way through you should be able to collapse the ring.
Hope this makes sense.
