Current thinking on winter storage: fuel
iconic944ss
The ST is probably off the road for winter now so I was wondering whats the recommended procedure for fuel storage these days?
I used to try and empty a fuel tank and then run the bike until it stalled but was told that the gas vapour left behind id more of a hazard than liquid fuel.
So... next recommendation was to fill the tank completely, use a fuel stabiliser and run the engine a while so that conditioned fuel gets into the carbs/injection system.
I did the latter for the last two years using a batch of Motrex stabiliser I bought and it seems to work fine.
Cheers - Fuelled-Up-Frank :D
Fill the tank, then forget about it.
These days, it takes a lot longer for fuel to break down, so leaving it for 6 months without additives should be fine, so I was told by DG!
I don't do anything specific for fuel, just coat the bike (brakes aside) with FS365.... works a treat.:thumbs:
I have always been a fan of the full tank and preservative option. It has worked for me over the last 6 years when I have hibernated my bike between October and March. Most often I use POR-15 Fuel preservative from FROST Auto-Restorers. The last 2 years has seen me use Wynn´s Fuel Stabilizer (from Ebay); Both have allowed the bike to start first time every Spring. :D .
Never used FS365 or ACF50 before but am deffo going to this winter.....so which is best in terms of performance and price, thoughts please...
FS365 much easier to put on but washes off quicker. Mind if the bike isn't going anywhere it probably doesn't matter.
However if you want to give the bike a coating all over with ACF50 including the electrics it would see off the worst of the weather mext Spring.
Either will do the job for you if just storing for a few months.
Also discovered that a basin half full with some of the rocksalt/grit left in the garage helps pull moisture out of the air.
Last 2 winters the bike and garage contents have stayed bone dry (but need to empty the basin of collected water every couple of weeks)!!
:thumbs:
i'd say, pour a glass of vino and have a real good talk to your bike, at the same time, turn the wheels and make sure the pads are not stuck to the discs, put it in gear and make sure the clutch plates haven't stuck together, maybe wheel the bike back n forward.
i'm also going to raid the local rocksalt bins.
I leave the tank full over here. Sometimes we get beautiful days with dry roads in the winter that are great for a quick blast. I mean quick though cos thay are bloody cold too but it really makes you know you are alive.
Well the yells guy is going back to mums the morra in besides his red pal.
Normally , as in the last 3 years , I have just cleaned and polished and took the batteries out?
had the odd look and then started them in springtime, no fuss.
Just looking at Bruce's stuff.
How would I use it and does it work
Thanks
J.b.
Johnny boy, various of the lads on here reckon both ACF50 and FS365 work so....I've got some FS365 and going to lash it on the bike the morn, will let you know how I get on..BTW enjoyed the NYC sketch photies!!
Thanks for that Bruce,
i've no used that stuff and was just wondering if it's good
Normally my mums garage has been fine...
aye let me know if i should ,and where to apply :)
