Cooling Fan not kicking in.
Guido
Hi folks,
I have a problem with the cooling fan on my 748R.
It's not kicking in when the temp rises above the normal "kicking in" level. The fuse is fine.
I parted the white connector that comes from the fan and into the loom. I've run the bike up to temperature (nearing 100deg) and then put a multi-meter on the female terminals in the loom side of the connector. I'm getting a 12+V reading on the meter.
I then attached two wires to an independant battery I have and placed the other end of the wires on the fan end of the connector's male terminals. The fan fired up.
I then let the bike cool down, re-checked the loom end of the connector's male terminals and the reading was zero, telling me the thermostatic side of the switch must be working.
Pretty stumped now as to why the fan isn't working.
Not entirely sure whether they're linked but the temp gauge is working intermittently too.
Sometimes it works fine, sometimes (like now) it doesn't move off the stop at all and others it gets to about 80deg and then as you rev the throttle, the gauge drops on each blip.
Does anyone have any ideas as to what I could check next. i don't see the point in replacing parts just yet as all elements seem to work fine, just not at the right time.
Many thanks for any help.
Yours stumped-ingly....
Guy
fans............
hi man,
did your boots catch fire ?
if no, then it's no too bad.
Maybe the gauge is broken ,
maybe some other wee thing is not reading correctly,
if the bike is still going round the corners , then not so bad,
and as usual, its a ducati R version, maybe acting like a youth
hope it works out fine..:cool:
I think the fan is linked to the ECU, which tells the fan to come on when the thermostat hits a certain temp, so there might be a breakdown between the thermostat & the ECU, or the ECU might be faulty, or between the ECU and the fan....
Keep moving over 60MPH, then you won't need the fans.... ;)
Unlike the later models, on the 748/916 the fan is not controlled by the ECU. There is a fan relay, I think it is one of the ones beside the battery and, unusually, it is powered ON with the ignition switch. Between the output of the relay and the fan is a Thermo-switch mounted in the radiator hose connection to the horizontal cylinder. It is this thermo-switch that turns the fan on and off. There should be +12V fed to one side of it from the relay. When the temperature is high enough it switches the +12V through to the fan, the other side of which is at ground.
So, assuming the fan is ok, there are 2 potential failure points. The thermoswitch and the relay. My money would be on the relay being intermittent.
Derek,
You were spot on.
I hadn't seen your post until today but yesterday with the help of my neighbour we tracked the fault back to the relay.
For anyone else in this situation here's the stages we went through to identify the problem.
  • Connected wires from a 12v battery (we used a separate battery from the bike's onw battery) direct to the male terminals inside the white tubular connector that comes straight out of the fan. The fan fired up telling us that was ok.
  • We removed the Thermal Switch (the bigger and left hand side one of the two located in the hoses on the LHS of the engine. We did a continuity test of the swtich terminals cold. No circuit was found as expected. We then placed the flat face of the switch down onto an electric hob to heat it up. Once hot we did another continuity test and found there was a circuit thus proving the switch was working.
  • We then removed the connectors from both switches and shorted them both out using two pieces of wire. The fan failed to work.
  • This pretty much told us there was something else stoping the fan working. As stated in my first post the fuse was checked first of all.
  • Using a wiring diagram to deduce the full circuit we found there was a relay for the fan (Tyco V23075). This relay is the same as the ignition relay. We swapped them over and the fan worked thus proving the relay was at fault.
Ordered a few of the relays from - Vehicle Wiring Products
Hmmmm.
Nothing's ever simple is it??????
Recevied the relays. put them in and expected the bike to fire up.
NOTHING.....!!!!!
Fuel pump doesn't make the usual priming noise and the starter doesn't crank when I push the button
What would stop the pump priming/working????
Side stand is up so it's not the cutout.
Thanks in advance, Guy
Maybe the new relay is incompatible? Try re-fitting the original ignition relay. Is the kill switch ON, it's easy to miss that.
Thanks Derek,
Not sure how you check if the relays are compatible. You only have the pin configuration and numbering (30, 85, 87a etc) to go on. The kill-switch is on too.
I've ordered two replacements for the two large square block type relays that are under the seat. Aren't these ignition relays???
Just thinking about it. There isn't that tell-tale click from under the seat nor the fuel pump priming whirr when the ignition's turned on. Would duff or goosed under seat relays cause this???
Hoping to get it sorted as I'm supposed to be leaving for my annual bike holiday on Wednesday and time's running out when I lose a day between waiting for parts deliveries.....
Thanks for all you help again Derek.
Gc
What Brian says.
The ignition relay is turned on by the ignition switch and it turns everything else on. Virtually nothing will work without it.
The 2 relays under the seat are for the fuel injection. One is for the ECU (the injection relay), the other is for the fuel pump and coils and is turned on by the ECU. If it fails there is no pump, but if the injection relay fails there is no pump either. There is also a 5A fuse for the ECU and if that blows, again no pump.
Thanks Chaps.
The fact that the tell-tale click from under the seat has stopped I'm hoping it's the under-seat relay/s that have gone. I have two on the way which should be with me tomorrow. The 5A and 20A fuses under the seat are fine.
I'll have to keep my mouth shut. When I got my rebuilt engine back last week I said to my long suffering wife, that nothing else can possibly go wrong with it as everything internal has been replaced (crank, rods, gearbox (twice), bearings etc). It'll only be minor electrical probs i have now.................................:)
Hi Guy
I think the relays are slightly different ,the ignition relay,the yellow one is a 5 Pin Single Common Contact Twin Output 'Normally Open' Standard (mini) Relay,that'll have two number 87's,effectively two commoned o/p's,although only one is used ,hence the 4 wires from the relay base.
The underseat relays as Derek mentioned are ECU and pump and are 5 Pin Changeover contact Standard (Mini) Relay.They should have an 87 and an 87a,87 being the switched contact when energised.Just make sure you've sourced the correct one,and the rating is correct 40a I think for the yellow ignition one.The underseat one's are interchangeable.
Thanks for that Chewie,
I've got a new 40amp Ignition relay, although the original sounds like it's ok as it's clicking when t he ignition is turned on.
I've bought 2 new underseat relays 12v 30A with 30, 85, 86, 87 & 87a pins
Still I have no clicking from under the seat though and the fuel pump isn't priming.
I've just spoken to John Hackett and he recommended removing the ECU connector and pressing all the female contacts home in case any aren't bedded properly. He also recommended cleaning all the contacts and pressing home connectors for the relays by the battery.
Done all that and still no click from under the seat or pump prime.
Really bugging me as everything worked fine upto Tuesday when we shorted out the fan switches to test the fan and then swapped the micro relays over near the battery. After then all dead.......................................
So I'm not throwing good money after bad..........If the numbers on the relays match (i.e. 30, 85, 87, 87a etc) should they be the same as the OEM ones I'm taking off or do they differ inside in what they're doing, meaning you have to get the exact same part numbered product (which I doubt myself)????
Thanks again......
Yours giving up..ingly.
Hello Guy
If main ignition relay is coming in I'd be tempted back to the sidestand relay,the small one next to the main ignition relay you should hear it click,maybe check the relay fuse, base and the associated wiring,make sure it's working before moving on.
The underseat Relays are standard c/o 5 pin (mini) relay so they're fine keep them as spares.
Hi Chewie,
All relays seem to click ok apart from the ones under the seat.
Not sure if it's related but have no starter either.
When you say "Relay fuse" where would that be located? Checked all visible fuses and all seem ok. Not sure of a sidestand relay fuse......
Thanks again. Guy
Hello Guy
Sorry I meant fuse 8,which according to the drawing I have feeds the sidestand relay ,located with the others.Then the two independant ones for the relays under the seat the 5a one for the ECU and the 20a one for the pump.If you can feel or hear the sidestand relay click when you lift the sidestand then the fuse is obvviously ok .The two relays under the seat are effectively controlled by the ECU so it's conditions coming into the ECU which determine whether the proper signals are there to enable the bike to start,that's why there is no starter and no prime of the pump,untill the conditions are met ie run/kill switch,sidestand sw/relay,are properly set the two underseat relays will do nothing.If the sidestand switch relay is definately clicking,you can probably assume it's working ,so you may have to check other associated things run/kill button ,ignition switch,associated plugs/sockets and wiring to Ecu.Coincidentally the ignition relay and fan relay are closely tied feed wise,according to the drawing I have there is a plug/socket between the ignition switch and the ignition relay,may be worth a look
Take the 19/22 pin round metal main harness plug apart , above the battery and check it for
corrosion as all the information travels through that one plug.
brian.
The plot thickens...................
It appears I have a short somewhere on the line that feeds the "Right Switch" 3A fuse. This fuse blows when the ignition is turned on. Checking continuity across the terminals of the fuse holder, I get a beep on both sides when holding earth against the chassis and positive against the upper and lower parts of the holder.
I've split the kill switch and everything seems fine with no corrosion or anything visibly untoward. This goes to an Ampliversal connector in the headlight bucket that looks clean.
As the bike ran fine up to Monday when we were shorting thermal switches out to check the fan status, I can only assume somewhere along this brown/black wire we have a melted point that is earthing against the chassis or another wire. Does anyone know of a potential weak spot or point where heat may build up along this line and cause it to "go"??? Might help me narrow down the search.
Incidently, I get a continuity bleep on the 3A "Right Switch" fuse holder (both sides) when either the negative battery terminal is disconnected or the positive. The only time I don't get continuity is when I split the harness at the big round connector Brian speaks about. The connector appears fine with clean, un-bent pins and no visible "trauma" to wires (issue is at the front end of the bike perhaps?????).
Many thanks once again.
Guy
Hello Guy
Try and isolate the part of the circuit where you think you have a short,it's hard trying to meter out a circuit with ancillaries connected .Disconnect all the parts that can be easily disconnected,all switches off,in neutral,including relays,ECU,metal pin harness plug/socket.Make sure that the kill switch is in the off position,or better still ,I think there's a 4way plug/socket to the right hand switches that will isolate them.Check the part of the loom where you suspect you have a short,if its clear ,start connecting parts,4way connector,kill switch,metal pin harness plug/socket ,relays,(underseat),ECU.Check before you connect each part in turn to see if youre short has re-appeared,if it does it's likely to be on the part of the circuit you have just re-connected.When youre metering the circuits disconnect the battery and check between the frame and the circuits.
I'm heading off on holiday today for the next fortnight and won't be on-line. However, a wee tip I've found handy a few times. When trying to find a short, substitute an indicator bulb for the fuse. The bulb will limit the current so nothing gets damaged and it will light up brightly when the short is there. Disconnect circuits downstream of the bulb and when you disconnect the one with the short the bulb will go out or only glow dimly. Saves a fortune on fuses. Good luck.
Thank you very much once again Chewie and Derek.
Been away for 3 days (on a trip that should have involved the R sadly - hey-ho)......
Will have a go tomorrow night. That tip with the bulb is great Derek as I was going to buy a job-lot of 3A fuses tomorrow (if I could find someone with them in bulk)........ Hope you have a good holiday.
Fingers crossed that I find the culprit circuit soon.....
Guy
Ok had another stint on the bike with a chap who is pretty good with electrics and then a nieghbour this afternoon.
What we think has happened is I 've suffered an EMP (Electro-Magnetic Pulse) surge when I removed the relay with the ignition turned on. This means the fault could be anywhere along the wiring loom........bummer!!!!!
We're fairly sure the fault is in the loom itself and not any bolt-on ancilliaries like fuses or relays or the ECU itself. I'm hopefully getting the length of loom that goes from the battery to the rear of the bike checked out tomorrow. Will report back once I have some findings.
Well.
I had to admit kind of failure on this one.
After extensive checks of different possible reasons why the 3A fuse would blow when the ignition was turned on, it appears the fault lies in the grey wire of the two that come from the loom to the sidestand switch ampliversal connector. That's as much as I can find out without stripping the loom out (again) and pulling all the sheathing back (again).
My neighbour's sparky mate has taken the sidestand relay apart and "shorted it out".
The bike now starts with the relay in but doesn't blow the fuse. I didn't want my sidestand controlling the ignition/fuel pump anyway.
Thanks for everyone's help and time with this.
Cheers, Guy
