Comfort Seat on Multi?.............How?
PaulV
I think I already know the answer to this question:( :( , but I am going to ask anyway................
Is there an easy way to fit these things.............???:confused: :confused:
I bought Chris' of him and after looking at his Italian instructions, cheers Chris, it looks like it is a major job. Any and all suggestions welcome..........................................................................................................................................................................that's not an invite for sarky comments.....you know who you are!!!
No, its a longish job. All the tank/seat unit has to come off. Takes ages the first time you do it but about 20 minutes when you know the score. Theres detailed instructions somewhere on Multistrada.net
Theres nowt hard about the job its just you have to take a lot of bits off to get to it. Once you know where all the fasteners are its easy.
Make a start and post on here if you get stuck.
Sargant Seat instructions attached here, as Martin says first time it takes a bit of doing but once you know where everything bolts to its easy enough.
Cheers fellas................knew you two would help out with info/posts:D ....
Be worth it in the end.:) :)
Probably have a go at it later in the week, or at the weekend.
Fitting a replacement seat is almost a big a pain in the ar$e as the original seat is a pain in the ar$e.........but worthwhile in the end.
