Cold start issue - Monster 1100S
how Do you set the air gap when you put the new sensor on ?
on the triumph I had the misfortune to own the ignition pick ups broke down for fun and if the air gap wasn’t spot on it ran like shite
wonder if the heat gets to them , been close to the cylinder
I’ll double check in the workshop manual but there appears to be no way to check it ie there’s no additional hole on the side to get feeler gauges in as there is on the 748/916/996/998 range of engines Additionally there were no shim washers on the cps when I took it out. I can only assume the sensor at 21mm is designed to be exactly the correct distance away from the flywheel when it’s inserted.
The part diagram doesn’t show any shims, but only shows 1 o-ring 🤔
Yep, I don’t believe there are any shims, just the o-rings, there’s actually 2 inside the hole in the crankcase. I can’t see how it’s possible to set an air gap, it’s got to be just fit it and it fits. I hope.
I was in the shed whilst @Nelly was writing to me (thanks Nelly👍) as I’d decided to remove the CPS and check it over anyway. Blimey, it’s a pig to get to, not like the 916 range at all. The sensor itself sits on top of the crankcase and is fiddly enough to get the bolt out then the sensor itself out of its hole; it’s a tight push fit through 2 o-rings. But the connector is on the other side tucked away behind the frame spar just under the tank, what a PITA 😡.
Anyway I got there in the end and after all that it all looks ok but who knows what’s going on inside it🤔.
I came back into the house to do some research, saw Nelly’s post so ordered up a replacement, surprisingly the cheapest place was the one snd only Ducati dealer in the Republic albeit I’ll have to wait as they have to get it from Italy. At €68 delivered it’s not as bad as I thought and 1/2 the price of the Ducati one for an ST2 (which is why I got a Fiat part for £25).
I’ll fit it when it arrives and see if that cures the issue.
Now my enquiring mind needs to know why and how it failed or is failing and how the ECU can detect its failing 🤔
View attachment 5973View attachment 5974View attachment 5975View attachment 5976
It's a Bosch, that's your issue 😁
Even better
:confused: where were you when I needed you. The cheapest I could find, even when searching for he part number on ebay, was about £40 odd plus they wanted £21.99 P&P o_O.
Anyway, thanks for those and I've bookmarked them for the future now, plus anyone else who comes along and reads this thread will see your posts so that'll help them (y)
An update as I don’t like to leave threads hanging.
The new CPS arrived just before Xmas so between Xmas & New Year I fitted it, pressed the starter button hoping.... oh ffs 😡 exactly the same issue. She spins over ok, catches for a split second then doesn’t continue to fire up. Pissed off the CPS was not the issue I just left it until this morning.
Determined to get to the bottom of it I think I’m going to go back to basics. Fuel, spark.
Thought I’d just try it first just in case. Key in, ignition on, press start, same issue 🙁. ignition off, on, try again, leave finger on the starter button, same thing, just turns over. 😟
Detach the tank and prop it up, but still connected, Detach the ECU. Remove the air filter. Think, perhaps I’ll just squirt some EasyStart into the airbox now the air filter’s out and see if that starts it. BINGO. 😁. But why?
Leave it running a bit, blip the throttle a lot coz I like the sound😄. Turn it off. Air filter back in, it still starts. Tank back down, it still starts. Tank breather reattached, it still starts.
So now, great, it’s running again but what was the issue? I hate it when an issue arises then just disappears. Bike’s are not women, there has to be a logical explanation.🤔.
It's had the vaccine?
Some assuming the human element here hasn't fooked it up, or the classic its cold the battery is low the starter takes all the electric the spark is weak you turn it and turn it with a weak spark and end up flooding the plugs which makes it even harder to start...So check 1 full charged good condition battery
check two dry spark plugs before trying to start.
So Ducati must of applied something for a cold start, there must be something in the ecu linked to temperature both ambient and of the engine that facilitates for cold start. and stays in until the engine reaches a certain temp... a bit more of a sophisticated electronic answer to a choke or fast idle lever... at the end of the day when its cold less air or more fuel will up the CR give a bit more bang and help it idle albeit faster until its warm...
So I would research cold start circuit or sensors associated with temperature..for example one chappie is saying high will level interferes with his cold start....once he set the oil level correct it started fine in the cold.
I always suspect the human element but I think all is good in this case (y). It first started playing up towards the end of the 'season' when it wasn't so cold (it's about 4c here at the moment) in as much as it would struggle to start when cold but would eventually, although it was a bit lumpy on tickover until it had warmed up.
The present cold weather and battery condition is a good thought although I am fairly confident the battery is good, it's definitely fully charged as I have an optimiser/charger which gets moved around the bikes regularly to keep their respective batteries topped up. As it hadn't been cranked over for about 10 days or so the plugs (4 of them) would have been dry and as said above it does (did) catch just not enough to continue and then wouldn't do it again (until it did if you follow me).
It has a stepper motor which assists with cold starts by altering the air flow after the throttle valves thus no need to open the valves. The degree to which the stepper motor increases the airflow post valve is determined by the ECU which gets it's info from a Lambda sensor in each exhaust, an air pressure sensor which is measuring the pressure in each manifold relative to atmospheric and a temperature sensor in the intake manifold of the vertical cylinder. In addition the ECU is monitoring the temperature of the engine via the oil temp (its an oil/air cooled engine).
When it did start today it idles at 13-1350 and as it warmed up dropped down to 12-1250.
I was going to look for anything obvious on all the sensors today hence I lifted the tank and was about to remove the airbox completely so I could get at the throttle bodies and the respective sensors but then it started - I hate fooking mysteries like this.
Is it recorded anywhere what the cold start idle speed should be? I'm wondering if that 1000 rpm is a big enough hike? but I'm also wondering about idle speed being high? perhaps an air leak in somewhere lifting the hot idle and impeding the cold start ie making it too weak?
According to the workshop manual the idle speed is 1300 + or - 50 so I’d say mines bang on. Again having checked the workshop manual there’s no mention of any ‘fast idle’ when the engine is cold and it’s within just a couple of minutes that it drops from 1300-1350 to 1200-1250
Ooh there must be something to less air or more fuel..
There are air adjuster screw thingies on each throttle body but otherwise it all appears to be controlled by the ecu controlling the injectors depending on what measures it gets from the lambda sensors but I don’t have the manual in front of me at the mo.
The ECU firstly rakes a signal from the engine temperature sensor (mounted in the horiz inlet valve cover). This determines how much fuel is injected. The servo idle control valve is reset every time the ignition odd turned off, presumably to the fully closed position. When the engine fires up the ECU gets the revs signal from the crank sensor and uses this to regulate the ICV to maintain a predetermined idle speed, this would appear to be temperature dependent as it is faster with a cold engine slowing to something like 1250rpm at running temperatures.
Paul's problem seems to be that the engine fires once but doesn't catch. Given that the bike runs ok once it does start then the temperature sensor seems unlikely to be at fault.
So it seems, as Andy says, that the air/fuel ratio isn't quite right. As the fuel is entirely controlled by the ECU there is nothing you can do about that. But each throttle body has an air bypass screw which determines how much air enters the engine when the throttle is closed. You could try tweaking these to see if it helps.
Locate the bypass screws and turn each of them all the way in, counting how far each turns to closed and note this down for each bypass screw. They will probably be between 1/2 and 1 and a half turns open, although sometimes you find them fully closed.
Return each screw to it's original position, then screw each in by 1/4 turn this will reduce the amount of air making the initial mixture slightly richer. Try starting the bike and see if there is any change. If it starts ok good. If not try another 1/4 turn. If still no good set the screws back to their original positions then try opening by a 1/4 turn. If that doesn't help either then I can't really think of much else.
Thanks Derek 👍 and Andy 👍will give that a go tomorrow.
Today's attempt.
Tried to start her from cold - again same thing
I know the battery sounds a bit tired there but I forgot to put it on charge after yesterdays several attempts at starting :confused:
Squirted a generous amount of EasyStart into the air intake before and while she was cranking and she starts.
Checked the bypass screws as @Derek suggested above - both 1.5 turns from fully in. Problem now is the engine's warm, well at least not stone cold anyway, so she now starts first press of the button. I'll have to wait until tomorrow morning now to start the process of 1/4 turn in on each screw.
As it starts when EasyStart is squirted in I'm now convinced it's an air/fuel ratio issue at start up when cold - although I'm not sure what could have gone wrong. I reckon I might have to strip it all down again to get to the throttle bodies and double check there are no splits in any of the hoses to/from the stepper motor or any of the other hoses that are feeding sensors that feed the ECU.
battery not helping and taking away precious spark from the plugs...
sounds very slow turning over.......what earth have you got on the battery to frame...
what voltage is in the battery across the terminals and what voltage is there positive to frame earth.....
ExactStart cable from battery to earth point on cylinder case.
you need to stop with the easy start shit.... you'll bugger something up!
Noted, was just experimenting.
13.14 across the battery terminals
13.15 from battery +ve to the frame
Naturally, as it was only running (albeit for no longer than a couple of minutes) about 90 mins ago it started first time
I reckon I’ll have to leave it now until tomorrow morning.
Agreed... just 'cause it sounds like a cross between a lawn mower and a chainsaw doesn't mean you can treat it like a GS!
