code reader.
fin
any suggestions regarding code reader for multistrada 1100s allready hav a snap on ethos with fiat alfa diag connector which fits but wont communicate.
intermittent starting fault and cut out three times on last run,(going over the lecht).
usual stuff done rpm sensor ect. should of done this over winter.
cheers will giv it a go. is it just me or is that a fiat punto mk2 ecu on this bike. looks familiar.
Same family but unfortunately not compatible. It does mean that should you ever need an ECU connector then a Fiat Punto loom does the trick cheaply.
well theirs yer problem.
same family, well theirs your problem.
best approach it like a punto then.
fuel pressure 3bar during cranking suggesting rpm circuit good.
spark plug resistance 5komhs and no missmatch on plugs (very important, on punto will switch of can system if incorrect)
punto coil drivers in ecu prone to faults.
battery voltage good not checkd at ecu.extra earths substituted
no spark at moment (broke down in front of competitors garage Wat a cock almost traded bike in yesterday but personally couldn't sell with this fault).
started to strip down down yesterday in between jobs finding green connections every ware.
a wee chat with george at ducati glasgow may hav put me in the right direction.
starter motor! spin engine over with rear wheel by hand sparks every time use starter
motor no spark even with car battery starters coming oot.
It might not be the starter motor itself but more likely a bad/corroded connection somewhere. If I remember correctly the ECU switches off below a certain voltage (9.5v -10V?). So the engine may well crank over but if the volts to the ECU have dropped too much there will be no sparks. Check to see what the fuel pump relay does while it's cranking. It should be on to power the pump and the coils.
never say never but delivering 3bar during cranking suggesting rpm circuit good fuel pump relay operating.
will recheck before removing. didn't check voltage at ecu. lent manual to some dude but didn't bring it back
would you know Wat pin to check at ecu.
thanks for that noticed that pin 12 nc not used? germin not so good, come to think of it nether is my English, chortle .but thanks again very helpful.will try later on as will go bankrupt if i dont get some paying work done.
well well well
who'd of thought it, after trying every thing to prove it wasn't the starter turned out it was, voltages perfect every ware, nats whisker away from sending away ecu
every days a school day.
