Clutch won't engage (Ducati 748)
Jared Earle
My poor old 748 is missing out on the glorious weather because the clutch won't engage. I've taken off the cover and the outer bit looks fully-out (disengaged) and the springs are fully-compressed.
I took this off and all the plates are in perfect condition, but the pushrod appears to be stuck in the out position.
Now, when I was a kid, I had this happen on my Suzuki GT125 and it was because the pushrod was bent by the rear sprocket, so that was my immediate thought. Ideas on what to do to fix it or is it a "call Ducati Glasgow" moment?
I hate missing this freak weather we're having.
ps. I asked Alex Briggs on Twitter and he kinda recommended a hammer. :)
Start by pulling the pushrod to see if it will come out - it should. What's happening at the slave cylinder end?
Pushrod doesn't come out with pulling. I'm now pretty certain the pushrod is bent and stuck.
As for the slave cylinder end, I'll need to get the Haynes manual before I tackle that.
Is the push rod solid or has it got a little movement.
The slave cylinder comes off with just the three M6 socket head screws NO need to disconnect
the fluid line.
brian.
the fluid line.
The pushrod feels solid. I'll nip out and remove the slave cylinder. I don't need to move the bike out to get to that side. Thanks!
Slave cylinder unbolts as above, it's a sealed unit, think brake calliper with one side missing, no fluid to lose, however, do not pull the clutch lever once it's out or you'll pop the piston and be wearing dot 4.
on the slave cylinder side,there should be a rubber grommit covering the push rod after slave cyl is off,if its not there,maybe its been "eaten" by the pushrod,and its whats making it stick open,also the shaft that the push rod runs in has needle bearings,could be them,or pushrod maybe bent,does the clutch run true when its turning? it maybe a give away that it could be pushrod related if its running out,even a little bit,this is just a helper mate,it could be lots of other things,but its a start. hope you get it sorted.
Update: fixed
I removed the slave cylinder and the rod was firmly stuck. Gentle bashing from both sides didn't move it at all, so I got Ducati Glasgow to pick it up. The pushrod was indeed seized into the engine block. They removed it, a job I could have done if I had the tools and workshop, and replaced it. The clutch is really smooth now and the bike feels great.
A fun ride home ensued. :cool:
