I'm surprised that you have had failures on 5 out 9 bikes. My own 2003 ST4s still has the original cylinder with no problems at nearly 19,000 miles. (It will probably fail next week now
Since about 2001 the slave cylinder has been an improved design that I believe has generally been much more reliable. It has a better seal at the gearbox sprocket although maybe not much else. The old slaves were made from aluminium alloy but the bores weren't hard anodised and would consequently wear. This was made worse by the poor fit of the pistons which would tilt in the bores and cause scoring. I don't know if the current cylinders are any better manufactured in this respect.
There are several possible solutions;
1. Fit an aftermarket slave from one of the many available. These generally have a larger diameter piston giving a reduced pull at the expense of lift.
2. Fit an X-Ring seal to the existing piston, although this depends on the piston and cylinder still being in reasonable condition. X-Ring seals are available from
Pro-Twins at a couple of pounds or so each. The seal on my last bike (900ss) leaked at 21,000 miles. I replaced it with an X-ring seal which was still fine when I sold the bike with 32,000 miles on it and still with the original cylinder.
3.
Evoluzione used to do a replacement piston which was a better fit with 2 seals instead of one. I don't know if this is still available.
If the pressure plate bearing isn't working correctly then the pushrod will turn along with the clutch. This can spin the piston and destroy the seal. I can't really think of much else as to why the cylinders on your bikes should be failing prematurely.
