I know this is a common problem, just wondered if anyone has had success with the aftermarket "square" seals? Or do I need to shell out for a new cylinder?
I fitted "Quad" seals from Pro-twins to the clutch slave on my previous 900SS and it was still working fine 2years and 12,000 miles later. They will work OK as long as the cylinder bore isn't scored. The trouble with the older slaves is that the piston tends to tip in the bore and score the surface.
An alternative is the Evoluzione piston with twin seals.
