Clutch release cylinder.
Tam
What a pigs ear. :eek:
Just been fixing Foxy's cylinder as it was leakin.
Off it came not a prob, pushed out the piston, not a problem. cleaned it all up,fitted new seals, lubricated and refitted not a problem. Gaiter back on, release cylinder back on and retightned, not a problem. On to the bleedin.
Fill up the cylinder,pump te pump te pump pump, let the air oot,keep doin it a few more times, clear fluid no air,top up the master cylinder,tighten the cover. No feckin pressure in the clutch lever. What's goin on. Foxy's lookin perplext and i'm like:dunno:
Know i've done everythin right so what's the Hampden Roar.
Decide to do it all again same thing,no pressure. I'm gettin @@@@ed off now but Foxy bless her cotton soxs has got faith in me and brings me another coffee.
She's a lovely lass;)
To cut a long story short i got a bite point but it was quite far in. Clutch is runnin ok and it's smoother but i still feel there's somethin odd.
Does it make much differance what fluid you use. Unipart dot4 being the fluid.
Got an air bubble at the top of the line at the reservour??
you could try cracking it off (with lots of cloth) and operating the clutch, then tighten it back up - may work! :)
Got all the air out Ed. Clear as day fluid. It just took ages to get some pressure in the lever. The bite points way back. I've suggested screwin the adjuster in on the lever, but she's just got home and said it's a lot smoother changin gear and it was fine.:confused:
Thnx for fixing it Tam and sorry to have spoiled your night with a 20minute job!! (hope there wasn't any footie on now that I think about it:confused: ) It just wasn't logical that there was no pressure after putting it together and bleeding it the first time but - hey - you got it sorted :thumbs:
The clutch does feel good other than the biting point being far in, but after the first change that wasn't a problem.
Guess that's another pint I owe you then at the Masher, and another slap too if memory serves me right :beer: :twak: :D
Don't worry,your fittin my clutch plate and springs;) :p :D
Nae botherl - I've got a haynes manual with pictures too you know :p
talking of clutch plates - have you checked recently that your lovely new shiny red one is still on the table :D :D
Aaaaaaahhhh. Didn't look hounest:p That's one slap less i'm owed:D
Tam,
The bite point so far in suggests there might still be some air in there. Adjusting the screw at the lever can end up with the piston not returning far enough to uncover the hole that allows the fluid back to the reservoir. This ends up with lever feel becoming very hard and the clutch slipping.
Air trapped at the top banjo can be got out by tipping the bike so that the master cylinder is higher than the banjo and gently "jiggling" the lever. With the cap off the reservoir you will see a stream of tiny bubbles rise from the hole at the bottom. When they stop there's no more air.
I've usually found that it's easier to do this by removing the master cylinder from the bars.
Cheers Derek. Just couldn't figure out why it was so far back when i had clear fluid at the bottom. Foxy says it's runnin nice,it's just the initial release from first gear.
