Clutch Question for Derek
winston
Derek.
I have a Mutistrada 1000ds which has covered 20,000 miles now and the clutch is getting a bit snatchy/unpredictable, sometimes accompanied by that 'graunching' sound. I was thinking of replacing the plates (and possibly the basket). I haven't inspected the clutch yet but from reading accounts on here it may well be the tabs and/or slots on the basket. What I'm most interested in was your article on a 'Quiet Clutch' from July. Is this really a simple mod bearing in mind the last clutch I took apart was a Honda one 20 years ago in my mums kitchen ? Actually the whole bike was in her kitchen stripped down......... but I did pay board - had to wait ages for a cam chain and tensioner from Japan which she was most displeased about.
Thanks Ed :rolleyes:
Hi Winston. At 20,000 the clutch will definitely be showing signs of wear but might not be worn out yet. The graunching is quite common on most Ducati dry clutches and often taking the plates out, cleaning them, giving them a shuffle and re-fitting them cures it, although it usually comes back sooner or later. Shaazam reckons it's caused by a resonant vibration in the clutch pack.
The snatchy unpredictableness is another matter though.
I suggest taking the clutch apart and removing the plates, a magnet and a small thin bladed screwdriver helps to get the plates out. Once it's apart have a look at the friction plates. The tabs on the outsides of them get a hammering as they rock back and forth in the basket's slots - that's what makes all the noise. As a result the edges get mushroomed and the noise gets worse and worse. This doesn't affect the clutch operation though as long as there is a reasonable amount of friction material left. There is very little to begin with, even on new plates.
Then have a look at the slots in the basket which the tabs bear against. With the hammering, over time these will get notched. Eventually to the extent that the plates will stick on the notches when you pull in the lever. This will result in the plates tilting and sticking against each other resulting in the clutch having an unpredictable behaviour. Sometimes it will drag, sometimes it won't. sometimes it won't release at all and sometimes it will slip.
When the basket gets to this stage it is best to replace it. The slots can be filed to restore the straight edges but this increases the play between the tags even more so it will be even more noisy and wear out even faster. I suspect most Ducati clutches are replaced long before the friction material has worn out because the tabs have become mushroomed and the basket slots notched.
The main reason I did the quiet mod was that it mainly prevents the chattering of the tabs in the basket and hence should greatly reduces the wear on the tabs and the basket, hopefully extending the clutch life considerably. There is now over 23,000 miles on the clutch on my bike and it still works perfectly. It will be interesting to see how long it lasts.
Winston,
I've done the mod to my 900SS - and it takes no longer than changing the plates normally does ... about 15 mins including taking fairing off! ...and it's really weird not having the clanging sound anymore ... a tip when taking the plates out ... get two pieces of stiff wire (coat hanger type) about 8" long and bend little hooks on one end of each piece; they can then be used to get the plates out easily - magnets are ok, unless you've got alloy plates ;)
If you can get over to Duc Manc on Sunday I should be there from about 2pm - mines the tatty 900SS (red, of course) with a double bubble red screen .... you can hear the diff for yourself and decide if its for you...
Bert,
It's only the friction plates that are alloy and they've got tabs you can pull against. The plain plates are steel. The bent wires are still a good idea though.
True .. or a least mine are steel anyway...
Basically at the time I did it I could see an old wire coat hanger handily at the front of a box of scrap bits in the garage, and couldn't be ar5ed to rummage around for two small magnets out of the bottom of my tool boxes :)
...and as it turned out, the magnets were stuck to the outside of the toolbox anyway :banghead:
Thanks for all the advice. I'm still having problems starting. My starter motor is great now with the new bushes. However, the bike has been standing for a week so I thought I'd charge the battery in the mean time. Only took half an hour on trickle charge. Tried to start this morning after a few abortive attempts last night (and doing a runner after setting works fire alarm off) and the bike wouldn't start. Checked plugs and they're sparking ok. Then the motor wouldn't turn. Checked the resistance across the motor and that's fine (unlike when I started all this when there was none). Checked the battery voltage and it had gone down to 12.3v. My friend has a Triumph 675 and his battery failed to turn his motor at 12.3v. The Triumph dealer said it needed at least 12.7v to start and that his battery was faulty. Sure enough we tried a new battery and it fires every time now. My symptoms are exactly the same. The relay is ok and power is getting to the starter. I suppose I could try my car battery first with some jump leads before I buy a new battery. I've just charged the battery again after work and it's only taken 45mins on trickle to fully charged. The battery is nearly 2 years old and apart from two weeks both summers the bike has been used virtually every day and with the duff bushes of late has taken a few belts to get going. Could the battery be on its way out bearing in mind that its not taking long to trickle charge ?
If I get it going tomorrow I'll come over to Duc Manchester on Sunday to have a look at your clutch mods Bert3 if you don't mind as I am very interested about reducing wear/noise.
If my plates and/or basket are/is worn what's the best replacement and how much would I likely pay. Would I be better keeping my original plates for the mod ?
Keep the old battery. Put 2 long screws on to the terminals with lock nuts. Instead of all this jump leads nonsense Winston, simply press the battery terminals against the fitted battery on the bike and hey presto.....instant jump start.........takes seconds to do rather than muck about with leads :thumbs:
See Derek, I kept quiet! :p
Funny though, I understand you so much better when you write things down!!!!! :eek: :D :D
Winston, Surflex clutch pack, light-weight clutch basket. I've got an alloy one, hard anodised and as good as a steel one. A telescopic (car aerial type) magnet is a godsend in the art of whipping the clutch out quickly! :)
The mod is also a good one to for which I thank Derek for and apologise for my initial cynisium (can't spell that!):eek: :p
Thats my practice golf ball stash or when im feeling really bored, I like to bounce them down the bypass when its rush hour :D
...stop trying to bring blo0dy golf into every thread on this forum yer bawbag!!!!! :eek: ;) :p
Aye weel, ah kin sin soart that oot, ye jeely-faced gadger :D
Ed's advice is good, don't know what they cost though.
and Ed - thanks for the thanks despite your initial cynicism :p
Been into Ducati Leeds this afternoon to get a replacement sidestand switch. Chap behind the desk was very helpful re. starting problems suggesting a number of things it could be. Anyway the top and bottom of it all is that the bike now starts but only if you open to half throttle when starting and gulping through the airbox. After that it idle and revs ok. I'd replaced the battery and plugs this morning with new. After running for a while I took all the plugs out and the motor is running rich. Although that could just be the amount of fuel in the engine due to repeated starting attempts over last two days. I suspect though that I may have an airbox problem and need a new filter. I could kick myself cos I should have got one whilst at the shop. It's about 25-30 miles from where I live. I had suspected an airbox problem for a month or so as occaisionally for no apparent reason the engine stalled. With a new air filter and clutch the bike should run like new as I've changed belts, plugs, oil, oil filter, battery and sidestand switch. Didn't have time to stay in the shop to browse/chat as my bike's in a garage with only natural light so apologies if anyone was offended at Leeds.
See if it starts better with the filter out. As long as you don't run it long it won't do any harm. Bugger to change the filter on the Multi though! You might as well just change it anyway :)
cheers Derek. As I understand it takes about three hours first time around. The Sureflex clutch plates that Ed mentioned are about £180. I thought they might be around £200 so no shock there for a change. There is an American shop (Desmo something or other) that sells complete clutches with basket, springs, plates etc. for $660. I'm going to get up at 6am in the morning, go down to the work's garage and if it starts ok I'm going for a run and then meet up with Bert3 at Ducati Manchester to talk through the clutch mod. I'm not a slave to something I don't need so I don't want any bling bits
Winston, if you do need to change the air filter etc then you are welcome to bring your bike round here. Should be able to do it in less than an hour. It is a bugger the first couple of times you do it.
Martin
Just sent off for a new air k & n air filter from Ducati Manchester. I'm all over the place this week so can't call in anywhere.
Do you know if the Staintune stainless down pipes will fit into a Termi silencer ? I like my Termi but the downpipes look shabby now. They looked good when first painted but the heat's got the better of the paint.
