Clutch problems
jadey
Hi. My first post. Cant believe it. Bought my first ducati (996)only last week, and already it has let me down. This morning i took it out for a ride , on selecting 1st gear it jumped back to neutral and the clutch lever went stiff to operate.When you now select a gear it finds it but as soon as you find biting point it seems to slip out of gear. On operating the clutch you get at grinding noise from it. Is it fair to say that the clutch is shot?
Welcome to the site.......shame about the problem..:(
Sounds like it could be shot. It'll take two minutes to get the clutch cover off and have and have a quick look and poke around...
Ducati Forfar will be on at some point no doubt, probably diagnose it spot on foryou!:)
go to the tech library and you'll find a couple of good articles on clutch pack and tuning you can easily check if the plates are worn , not sure thats what it is though unless clutch hasn't engaged enough to let gear go in solidly
Thanks guys. Hope its just the clutch. Thinking back, i was getting a bit of clutch judder. I put this down to the fact that it is a dry clutch as it is my first experience of one. Anyone have an idea of what a new clutch will cost fitted from a ducati specialist?
do it yourself, its about as difficult as changing break pads, you only need two Allen keys (and a couple of magnets makes fishing the plates out easy)
I would also check the push rod isn't bent before you go down the new clutch road - that might cause a stiff lever if it's snagging.
after you dismantle the clutch (as Scotty say's - it's a piece of pish)
take the rod out & roll it on a sheet of glass
Can you tell us if the clutch is making the grinding noise as soon as you pull the lever, when you try to engage gear, or as you release the lever?
Without knowing exactly it is difficult to establish whether the problem is with the clutch or the gearbox.
Hi derek. Clutch makes a noise on pulling lever in. Just had a quick play and found out you can find all gears apart from first. Still slips out of gear on biting point.
Hmm. Sounds more like a gearbox problem than a clutch problem. Can you tell where the noise is coming from? Does it sound like it is from under the clutch cover or deeper inside the motor?
As an addendum, the push-rod also needs regular greasing, often forgotten. Whip the slave cylinder off (next to the sprocket cover) and it will pull out. If the clutch is stiff to operate, it could be bent, siezed or as Derek indicated worst case scenario, the gearbox could be ill. Jumping out of gear isn't good sounding, and wouldn't be related to the clutch. If the clutch is slipping or juddering then fcuked it is!!! :(
My 996 made an almost scraping noise when pulling and releasing lever, which turned out to be the clutch slave cylinder, replaced with DP unit.
Me again !. Right. I have taken the slave cylinder off and tried to pull out the push rod. Its stuck solid. Is it just the three bolts for the slave cylinder i need to remove. The pushrod will not go in or out.
the push rod fits into the pressure plate at the other end, its just a push fit but can be tight. Might be easier taking the pressure plate off?
...this is the norm for a neglected Duc (no disrespect to your good self). They are always forgotten and sieze.
yes just the 3 bolts hold the cylinder on, if your're careful, use a pair of rubber tipped plyers and pull the thing out, if it will turn, it will come out. Once out, give it a thorough clean, there are 2 'o' rings on the cylinder end check their condition and remember they way it goes back in. ;)
If you can, use an old straightened metal coat-hanger with some kind of cloth wrapped around it, douce it in something like panel wipe, petrol etc. then clean out the shaft in which the rod sits. Then plenty of grease much like you would a wheel axle. Good luck :)
...still concerned about it jumping out of gear though. But elliminating the clutch/push-rod issue will highlight whether it's the box or no. :)
Agreed. The push rod can be a very tight fit in the button in the centre of the bearing in the pressure plate. It may be easier to take the pressure plate off and see if the push rod wants to come with it.
Yes. If the clutch is proven to be ok and it still wants to jump out of gear there might be a problem with the gearbox. Jumping out of gear under load usually indicates worn dogs on the gears and it's usually just 1 or 2 gears that are affected, but jumping out of any gear when you try to engage the clutch suggests either a problem with the selector mechanism whereby the gears are not being fully selected or perhaps something amiss with the detent plunger.
I would also advise on a new clutch pack, check the clutch basket also, it will inevitably be worn out, the clutch plates effectively 'machine' their way through the basket. They can't go anywhere but they cause excess 'back-&-forth movement in the clutch with the net effect of making it much louder than it normally is (which is pretty loud at the best of times!) To check this, just hold the pressure plate and attempt to turn it, it will have back and forth movement (this is the back and forth movement I was referring to earlier).
Thanks Everyone for the advise. Decided its all to technical for me. Sent bike to a local ducati specialist, Cornerspeed of kirkby in ashfield. Anyone know of them?.
Dont here of them much on here due to location compared to where members reside but they get lots of great praise on DSC. Think your bike will be good hands...
Yep Nelly is a top fella, highly recommended and a good laugh also, he'll sort it no problem.
Hi all. Just a quick update. Bike now fixed, turned out to be clutch slave cylinder. Thanks to nelly, my pride and joy is back on the road, what a top bloke.
good news, clutch slave cylinder was a common fault on them, most should've been done by now!
