Clutch problems
853RS
Had an ST2 in recently with clutch problems.No pressure at the master cyl so bled it up and getting a solid feel.
After checking it out found that the slave cyl was full out and clutch just disengaging.
I think Ducati changed slave cyl design about 2000 to try and make an easier pull on the lever.They also increased the length of the clutch push rod by about 10mm so it looks like either the wrong slave cyl or push rod.Made up a 10mm spacer and clutch now ok.
Manufacturers of aftermarket slave cylinders, such as Oberon, include such a spacer so that it will be suitable for either length pushrod.
