Clutch oil leak ?
Scotty
I seem to have a oil leak behind the clutch basket, between the engine case and the spinney bits, enough to end up with oil drip on the floor :(
before I take more bits off, is this a sign I've over filled the oil ?
can you even get the sealing ring as a spare part / how do you swap that out
and can I use kitchen silicone sealant to stick the engine case back on
cowboy hat at the ready ;)
Hi Scotty, There is a seal behind the clutch drum that keeps the oil inside the gearbox. It's item 16 in this pic.
It's not hard to change but you'll need to remove the complete clutch to get at it, so you'll need a clutch holding tool like this
or this.
The centre nut needs tightening to 181 Nm so you'll also need a torque wrench.
No engine cases need to come off so you won't need any gasket goo but if you do it's worth investing in a tube of 3-Bond from a Ducati dealer. It's not expensive at under a tenner for a tube.
errrrm
seems to be from around the case to the spinney bit (the bit the clutch basket attaches to(clutch side rather than gearbox side ? )
don't know if you can make it out in the picture looks moist at the bottom of the seal
I can't really make any oil out in the pic. The seal is the bit I've coloured red.
You might be able to prise it out and push in a new one with the cover in place but it would probably be easier to take the cover off, in which case you'll need gasket goop.
