Clutch noise
Rossman_999
Hi there, my clutch has started making some very strange noises, to me it sounds like the plates are not fully disengaging causing a rattling noise but would welcome any other suggestions before I start stripping it down.
Its a 03 999 with 16K miles on the origional clutch, running an open cluch cover and have tried "blowing" away any dust using an air line, the clutch works fine and simply bliping the throttle is normally enough to clear the noise.
Check the bearing in the pressure plate first. I had to replace the one in my bike recently. The clutch was intermittently snatching on release with a hellish screeching noise.
It is easy to check and costs less than a fiver to replace.
