Clutch Master Cylinder
CJK
Clutch slave Cylinder
losing a miniscule amount of fluid each time I use the bike,cant find any weepage around the master cylinder though:scratchhead:,you can get a seal kit for them can't you ?
No you can't.
You can get a seal kit for the slave cylinder which is much more likely to be the culprit but it's often not worth fitting and you're better buying an aftermarket slave.
The OEM slave is pretty cheaply made. Dirt gets in from the sprocket/chain area beacuse it is badly sealed, the piston is a sloppy fit and tilts scoring the soft aluminium cylinder, and as the piston is steel and the cylinder aluminium, water absorbed by the brake fluid sets up an electrolytic corrosion process resulting in a rusty piston and a pitted cylinder bore.
With aftermarket slaves, both the piston and the cylinder are usually made from hard anodised aluminium alloy and are a proper fit with better quailty seals.
Getting back to your original problem. Are you sure it is the master cylinder? Have you found out where the fluid is going?
Masters do fail but very seldomly. The slave is much more likely. Take off the sprocket cover and look for excess dampness/oilyness around the gearbox sprocket. Fluid leakage is easily mistaken for excess of chain lube.
As Derek says its probably the slave cylinder,the one on my 916 went when I was touring on a trip around Scotland, I did notice the fluid dropping but I also noticed the clutch dragging and the lever pull changing. Any changes to yours?
Sorry Gents, meant slave cylinder i was partaking in :booze: last night when i was posting this :D
Any particular after market one to go for(don't want bling).
Dave the clutch lever feels the same,not changed,not too stiff unlike the Supersport.
They are all much of a muchness Colin. Yoyodyne, MPL, Oberon etc. Prices start from around £90 and up. Have a look on ebay.
just looked,pretty gunked up behind the sprocket,some traces of fresh clear fluid :rolleyes:(I've using dry lube on chain since i got the bike),the wee rubber gator has drifted away a little to.
