clutch ing at bearings
wheelybin
I think I have found the source of a noise in my engine - see thread weeerr, gulp.
I now need a bit of help re the clutch housing bearings. If I hold the edges of the clutch housing nearest you, as you face the engine, I can feel play in it, I would say about 0.25 - 0.5mm. Is this normal or shoud it be "solid"
thats the clutch and "muckle" gear off, thanks to a DUN member who leant me a clutch holding tool. The gear does wobble on the shaft but cant feel much play in the bearings themselves, new bearings are on their way from DG. will let you know if it tightens up when fitted.
A bit of rock at the edge of the clutch basket seems normal. I was worried about same thing when rebuilding my SL, so fitted new bearings (from DTS just to be sure they were correct spec/clearance) - made no difference. 15k miles later, all still seems fine.
Bearings fitted and clutch centre nut tightened. Hardly any movement in the clutch housing now. Hopefully this will fix the noise, when its all back in one piece and full of oil and water.
Coo, look at that .. he's got one of them posh engine holder upper things ... whats wrong with wrestling it around on the floor like the rest of us eh? :)
aaaarrrrgggghhhhh,
new clutch "muckle" gear bearings, new front cylinder belt idler roller bearings and still not got to the root of the noise.
Is therer anyone out there in the scottish borders area fancy coming round for a listen and to throw in their ideas as to what else the noise might be . Maybe its my imagination and they should sound like this? I hope so but dont think so.
:banghead:
Thanks to a DUN member from down the road, my deep depression has down graded to perplexed, the noise is still there, but was also present on another Duke, I could hear it above the "exhaust note!!" all the way down the road. ;). I'm gona risk a run to DG to let their experts have a listen.
Thanks for all your help!:thumbs:
I've got an Ural for sale. If you like strange noises then you'll LOVE one of these. This one is the delux version as far as noises go as it was made about the time the USSR colapsed.
As a former Dnepr owner, I'm sure a Ural is positively quiet / reliable :D
Made it to work this morning, 70 miles and no change in the nosie. next stop DG!!:D
