Christmas Lunch 'ion' and Tyres
winston
Over Christmas lunch I was thinking about tyres (God knows why !) but here are my thoughts:
1. Adhesion. Too much and you won't go anywhere. Too little and you won't go anywhere. Lateral adhesion is far more important than linear.
2. Cohesion. There's not much of that between rubber and road surfacing materials. None at all. Dismiss.
3. Friction. Same as adhesion but this is far more important in the wet, that's why surface dressing (tar spray and chip) is much better in the wet because it gives more friction. Not good to fall off on though as it will rip you to pieces. Check 'Shell Grip' at all major junctions etc.
4. Suction. Don't know why this came in to my head but I was thinking of them bath mats with the suction pads on. If they're so good in the wet why don't tyre manufacturers make the cambered part of a bike tyre work the same for lateral/centrifugal forces.
And don't get me going on bike suspension. It's all wrong everything should be put in tension not compression. If you don't believe me get a piece of A4 paper hold one end in each hand and put an object in the middle (eg. a small cup) . The paper will fold. Do the same again but pull the paper first (tension) the paper will support the cup. Tensile forces are far more stable than compressive ones. That's why front braking does horrible things with stability in addition to shortening the wheelbase and changing weight distribution.
Oooh I have a troubled mind this Christmas. I'm off for more beer now.
Happy new year to you all !
