Checking cam belt tension
Crewy05
Hi all, am about to do the service and cam belts on my 916, have done the belts my self the last 3 times so i'm quite sure of how to do them, but when it comes to checking the tension I always end up checking it 3/4/5 times before i'm satisfied. I use the twist and the 5mm allen key check method. Just interested to know what other methods people use?
Thanks James
I have a Facom tension gauge (they seem to have gotten hellish expensive now) but these days I mainly use a guitar tuner app on my phone. On a 4V engine, 110Hz for new belts or 80Hz for used ones. For 2V engines I'm happy to use the 5mm allen key method but if using the frequency method it's 145Hz for new belts.
He makes it look hellish complicated to change the belts with all this marking dots on belts and counting teeth. I suppose it helps confidence with those who haven't done it before.
I thought the same thing.Still glad to see people take the time to make these type of videos though:thumbs:.
Andrew
I used the count teeth and dot system, thought it was pretty easy and tested the belts with the 5mm allen key and twist method. It was my first time at doing them on the 916, all i can say is thank you to those that post these vids on you tube :thumbs:
Thanks for all your reply's, looks like I need to get on my app store and download a frequency app. I seem to recall the facom tools around £60 when i first looked at buying one, i dont know what they cost now, but im guessing as with most things in life they have inflated the price on them now.
