Hi,
Thought some technically minded members may find this of interest: See attachment.
For several weeks I've had problems with starting my bike M1000 especially from cold when going to work in the morning - turns over but doesn't fire up but gets there eventually. Fully charge the battery and seems fine however sometimes when leaving work has problems starting. I'm told - new battery needed as the charging cct works - from cold measures 14.1 volts at 5000rpm but I reckon should be that at around 3000rpm. Perform the usual checks i.e rectifier regulator diode checks, Stator coil resistance and leakage to earth but all seem fine along with ac voltage. Anyway decide to carry a multimeter with me and make some checks when bike it hot. On measuring the battery charging voltage - it's dropped to 13volts - that's not right? Could be the Rectifier Regulator breaking down when hot ? Could be the stator dropping voltage when hot ? Tests undertaken - ac voltage - stator fine , stator coils resistance fine however when I re-check the stator to earth resistance I've now got resistance which isn't right. Because of this leakage resistance to earth I could measure a variable ac voltage between the stator output and earth - definetly not right. In the end the stator insulation has been breaking down as the bike gets hot and I've now replaced it and get a healthy 14.6volts across the battery at 3000rpm.
On visual investigation of the stator it showed signs of burning.
Geoff
Geoff
