The internal workings of electrickery components is not my strong point so forgive me with the questions below.
By stator I presume you mean the alternator?
Do you mean the coils of wire within the alternator?
In my question I meant the r/r is connected to the stator/alternator so the electricity from same is flowing to the r/r. It’s the output voltage of the r/r I was testing.
In my case the r/r passes all resistance tests snd diode, forward & reverse, tests yet when I did measure the voltage output across the red/green wires of the r/r it showed <2v. I’m just curious to understand both what could fail inside (as you can’t really disassemble them) and why one shouldn’t test the output voltage, provided it’s only for a few seconds to get a reading.
The other reason I’m enquiring is that I guess it’s theoretically possible an r/r could be putting out the required 14-15v yet there could be a component sited between the r/r and the battery which has failed and which is causing massive resistance which prevents the volts going to the battery to charge it. Thus it seems to me, to exclude this possibility, one needs to know the native output of the r/r.
Further, a reading across the battery will always give you the battery voltage, in the case of my brand new fully charged battery 13.1v which some may interpret as the r/r working
