chain & sprockets
slick280
Hi folks first time on forum so need a little help.
What is the score with chain & sprockets for a 748.Do you need to buy a sprocket carrier when you change for new chain & sprockets ?
No, if you keep the standard sprocket size 14/38 then you can use the existing Ducati sprocket carrier.
Change the chain and the two sprockets at the same time, as they wear out as a unit.
By the way, WELCOME. Mine is a Doppio expresso this morning
Chain & sprockets
Cheers mate,much appreciated.:D
