CDI - duffer's question
Dukess1999
I'm connecting up the rev counter facility on an aftermarket speedo, and it says connect the wire to the negative terminal of one of the coils, or if the ignition is CDI, to the positive terminal. Does a '91 900ss have CDI ignition?
Ta
No it doesn't Iain. The +ve side of the coil is connected to +12V, so connect your revcounter to the -ve side.
Thanks Derek, more dependable than a very dependable thing :)
You probably told me that when I last saw you, but in one ear and out the other!
