Cheers Lads,the Superspurt failed to run on both cylinders today,shes been sat for a month or so,was running ok before hand(maybe a little rich,but went like f*ck on wot) thought I'd go for a wee blat around locally then change the oil in her.
Suited and booted i was to
,no chance,one cylinder only,getting a spark at both but vertical cylinder plug was soaking up constantly.
I messed about for bleedin ages,I thought maybe the float was maybe stuck on that carb,it looked ok when i removed the bowl though.
Nothing was set before i originaly fired these carbs on,the bike ran so i left alone.
I'll stick it back together in the morning see what transpires but i really reckon i should be servicing these carbs over the winter.
Maybe the poor old girl is feeling the heat being the only Ducati in the fleet
