Carb Issue ??
CJK
On the whole the old Supersport behaved well over the Masher weekend but it did develop,halfway through Saturdays run,an annoying flatspot.
Between 3-4k revs,a flat spot come stutter occured only if the throttle was pinned .
It'll ride through that rev range whilst pootling at gentle throttle ??
Had a similar problem and cured it by fitting a Factory Pro nickle plated needle jet - as recommended by Derek. The needle jet wears oval.
I need to decide eh !
Preferred choice is FCRs but that'll be dependent on squirreling away £600 without someone finding oot :whistle:
Is this the needle jet thats prone to cause problems? I haven't hauled it oot yet as everything looks ok and I've enough bits laying already !
Does the needle look ok ?
That's the bottom of it. Now that you've removed the nut, lift off the valve block and tap the base of the needle jet up into the venturi and withdraw it from the top. You will have to look very carefully indeed to see any wear but it will be there at the upper opening where the needle contacts it. We're not talking about mms, maybe only a thou or two but it makes all the difference.
Hard to say if the needle is worn from your photo. Look for any shiny areas down the side of it.
Thanks Derek but now its the least of my problems,carbs are now junk,kak handed Colin strikes again(it has been a while)
that mixture screw has been stuck and the head chewed to hell since i got the bike.The break has dropped below the internal thread so trying to bond it back together is an even bigger waste of time.
Gutted,and if 007 pipes up fi his Moscow HQ and says FCRs I'll be upto Angus the night to help myself to his bling.
Never mind Colin, Pict might have a spare pair of Mikunis soon :rolleyes:
Is there enough thread left to hold the needle in? It's the O-ring that makes the seal.
No,it's broken off below the thread.
Even if I did try and botch it it's a risk and maybe a big risk after spending money on 2 lots of jets and gaskets etcetc.
Free. They were incomplete when I got them for 99p on Ebay 'cos I wanted the float bowls with the fittings for oil heating lines. From memory they're in decent nick, on a par with your pics above, but I'll check tonight.
Carb bodies look fine. They're missing floats, bowls, plastic covers, diaphrams, needle jets etc, but they have their butterflies and throttle & choke mechanisms. If you're going to be in Glasegae anytime soon let me know and we can arrange something, otherwise I can post them.
Colin, when you are swapping over the jets etc. remember to check out the needle jets. Here is a picture of one of the ones that I took out.
If you look closely at the hole you'll see that it slightly egg shaped towards the top of the picture. That's the sort of wear you are looking for, it's very easy to miss it.
  • Like
Reactions: CJK
Colin for the price of jets and needles would you not be better to splash out on new ones and at least you know there are no issues with them?
Jets are often less than a fiver so not as if it is a fortune to spend and take one thing off the possible problem list?
  • Like
Reactions: CJK
Came a half hour ago,thanks again :cool:
The general condition of them looks better than i had(out with the gubbed bit that I broke).
just had a read through this thread and cant help thinking what a braw bunch o lads n lassies we are..
re the help and unselflishness of some folk
well done to you all
:cheers:
