monster_998
Can anyone confirm if the idler pulley on a 600 2value unbolts from the barrel?
Ta muchly. I had look and agree it should.It should - see parts ficjhe at http://www.stein-dinse.biz/eliste/index.php
I assume the (careful) brute force and ignorance approach is needed?Yes, they are loctited in very securely.
Yes, that's what I used and it workedI assume the (careful) brute force and ignorance approach is needed?
I presume you are getting the barrels bead blasted or something. Can you be sure you can mask them thoroughly? At 43€ each they aren't cheap, it might be safer to remove them.The question now is, is it worth removing them? Would it be easier taping them up?
They're probably made by SKF under licence - I had the same issue with Darmah wheel bearings a number of years backThey are an SKF bearing and I hunted several bearing suppliers with part no but no luck.
I was thinking that too :thumbs:.....dont use heat cause the bearing seal looks plasticy
