Broken speedo cable
sam1176uk
Hi folks,
New member about to start my first job on my 748, the speedo cable has snapped.
Is there anything i need to know before i swap it over, i'm assuming i'll need to take of the fairings/nose cone/lights/mirrors/instrument panel to get at the cable??
Once done then i assume it's just a straight swap over, anything i can do to help prevent it snapping again?
You need to take everything you mentioned off, except the clocks - there is enough clearance betwixt the headlight shell and clocks.
When refitting, make sure that the cable runs straight up from the speedo drive. Occasionally, the drive rotates on the spindle and kinks the cable - may well be the reason your's broke and definitely what killed mine.
Apologies for the photo being blurred but it's dark in the shed :)
Thanks for the reply that helps me out!
It has just had a new speedo drive fitted and it looks like he has fitted it at the wrong angle which has caused the cable to snap.
Do I need to take the front wheel off the adjust the speedo drive angle?
No, just loosen the spindle nut and the left hand fork clamp. This should give you enough room to rotate the speedo drive, then tighten the spindle nut and then the fork clamp.
Hope this helps.
