Brembo Brake Rotor Paint
Christy
This may have been asked before, but I can't find anything.
Has come accross good match for the paint on the brake rotors of the early Monsters?
Ive used temperature resistant caliper paint on my car ok in the past but for a bike I think I'd be looking to get the rotors anodised.
Older (fixed) discs can still be separated and uprated to full floating by using appropriate bobbins.
Understandable - the OEM ones I imagine are the riveted type that my 900ss came with - they can be drilled but its a lot of work.
Suggestions anyone?
Yes you can bash them apart with a hammer. Support the outer part of the rivet with a socket or similar and with a hammer and punch knock the inner part through. You can use this method to turn your semi-floaters into full floaters by just easing off the rivets a little.
