Steve748
shouldn't cost anymore than a gallon of petrol and a box of swan vestas![]()
you trying to say he can't light a match first time
i think I'm still detecting a slight lack of smooth stopping
which i suspect might be rear wheel somewhere on the paddock stand it rotates freely but then theres a 'tight spot' but not the chain could this be the rear swing arm repair ? do i need to have the repaired bit faced square I'll bet I've buggered the bearings if thats the case now like hummm is it paranoia ?
I still haven't bought any HT leads yet
humm the buttons on this suss rotor just how free are they supposed to be ? , I can turn em with pliers but not by hand
and the rotor seems to be off centre to the carrier which i presume was giving me pad rattle
is it possible to remove the buttons or is that a rebuild kit sort of direction ?
A common sense approach is required when doing this![]()
You can convert them to full floaters with a hammer by placing a block of wood under the button and bashing down on the rivet that holds it together.
Ha! Ha ! The mad hammer man of Forfar :smash: :smash: :smash: :smash: :smash:Presently in a state of shock!![]()
Can't believe that this is the same Ducati Forfar that hands out the other technical advice here.Reckon someone has hacked onto Derek's computer.
