breaks again
Scotty
:rolleyes:
in order to 'put my mind at rest' im going to split and clean my calierps again
the question is this
i bought some new break fluid dot 5.1 (i was pressureised into this sale (it was cheaper and is aledgedly better))
do i need to do anything daft to flush out al lthe old dot 4 fluid ?
dot 5.1 is incompatable with other dot fluids have a got that right ?
[edit, - no i havent got it right , dot 5.1 is compatable with dot 3 or dot 4 but dot 5 is the silicone one and not compatable with the other's]
i never split brembo calipers cause you cant get overhaul kits for them. the 5.1 fluid wont do you any harm but it is really meant for something doing a lot of heavy braking regularly. like a race bike on a track for example. the 4. would have done adequitley for your needs
spliting calipers was 'easy' errm think i used brand new allen key to break them last time and maybe an extension bar
just a dab of wd40 or better on the opasite end of the bolt, anh had calipers mounted to fork legs to break em
remember dealer once mentioned they had trouble splitting calipers came back with screwdriver slits cut into the bolt heads
currently have calierps in component bits and washed up about to break out the sand paper (1200 grit) think ive chewed up the pistons a bit from last time :(
umm im sure i know a fair bit more about it all but think ive quite possibly destroyed my breaks in the process
5.1 and 4 cannot be mixed so if you have used 4 your m/cyl lines banjo bolts will be contaminated.Do not use it.Take it back and get your spelling machine looked at as well!!!!!
I dont think 5.1 is meant for road bikes,doesn't it deteriorate much faster than 4, which is for roadbikes.
yup quite proberly
dot 5.1 has better inital performance which tails off faster than 4 dot and the same again from 4 dot to 3 dot
and if you never wanted to change fluid you could run dot 5 but have 'spongey' breaks right from the off
all swings and roundabouts
[edit]
and i think i can take the extra break 'service' from 2 years to once a year
Well the hydraulic eng I spoke to says at high temps the 4 breaks up at diff times to the 5.1 and the possibility is there for you to end up in the no mans land where one is going off while the first hasn't recovered (this could cause you to lose the brakes for a time and fall off and damage your immac bike!EH??)he would never run it on his bike.We don't run it on the race bikes either(If you are broke I will buy you some 4):dizzy:
hummm the last thing i want to do is feck me breaks up more than they are already
i could flush the system with IAP first, or again am i just asking for even more trouble ?
umm freshly baked caliper
Scotty,
Dot 3, 4 and 5.1 are all mixable. If you are worried about having topped up with 5.1 flush the sustem through with Dot 4. In ordinary use on the road you won't notice any difference between any of them but under no circumstances use Dot 5.
Scotty,
this is exactly what i was thinking its just that Berto messing with my head the b@stid
