ian900ss
Just fitted my shiney new Brembo discs and new DP pads to the front of the ST and a new set if DP pads on the rear as the disc is good. Bled brakes and new dot 5.1 fluid all round. Front now judder-less and both front and rear brakes are VERY good, even before I have bedded them in. I had put DP brake pads on the SS a few months back and with the cast iron discs they are awesome. A recommendation by Harry at DG instead of the EBC ones I had purchased originally. I highly recommend them.
ST now stops as well as she goes. Old discs were getting quite near the min thickness. Think Derek said they were the original so that's just under 50,000 miles!
Not bad, especially considering the cost of new ones....
