Brakes grabbing
dan13
This is occurring on my CBR so apologies in advance.
My brakes were vibrating at high speed and grabbing at low speed, the discs were a bit beyond the max run out so I got some new ones but the problem persisted. I replaced the seals in all the pistons and bled the system with brand new fluid but this did not solve the problem. The pressure is fine and they vibrate very little at high speed but are very grabby at low speed, I have checked the discs and the run out is well within the 0.3mm limit.
When spinning the wheel by hand on a paddock stand it is symptomatic of a warped disc, could it be a master cylinder problem?
All the pistons are moving freely and retracting correctly and the wheel and steering bearings are ok it's a bit of an annoying mystery...
What happens if you apply the brake lightly when the wheel is spinning on the stand, does it stop in the same place each time ? how did you check the run out bearing in mind the CBR has a floating disc does it not ?
it doesn't seem to stop anywhere in particular however as you say the discs are floating but some of the new disc buttons are quite tight I've tried loosening them by jiggling a screwdriver in them but some are still tight (you can't move them around by hand) maybe it's a manufacturing fault....is there any way to loosen them?
