Brake line fouling
CJK
has anyone ever made up a better bracket to guide the braided brake lines away from the forks ?
not sure if you can get them specifically for Ducati, but many race stockists sell small brackets that route the lines so they don't rub on the forks.
Will see what I can find...
I've got little brakeline 'p' clips somewhere I took off a bike (not allowed clipped lines for racing)
You can have them for nowt as I'll never use them.
Colin these are very common on older bikes including Ducati.
If you check the fork leg diameter you may be able to get a pair from one of the classic suppliers.
If you let me know the diameter I will check on sizes on mine to see how they compare.
OK, so this is on a mountain bike but: it works; it's cheap; it's variable; it's simple! Zip tie, short length of poly tube, bit of experiment.
Have these on the front mudguard for the speed sensor
cable and for the oil feed pipe to the heads you can get them in different sizes and colour from Earls at silverstone.
brian.
I forgot to say, I have the patent pending on these. OK to copy but you owe me a penny for every succesful one you use. Or the boys will be round......:eek:
Better send the boys round to the KTM factory :lol2: The've been doing this on their dirt bikes and motards for years ;)
