Brake fluid hose spec.
Dave G
One of the jobs I have to do is to fit three Rizoma fluid pots onto my SC, I could just bung them onto the existing black hose that connected the OE ones to the master cylinders but that seems a wasted opportunity when fitting bits of shiny stuff.
I know I can get clear or green hose (I'll measure the actual diameter when I get an opportunity) and have seen some on ebay
http://www.ebay.co.uk/itm/111215279138?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
(possibly the right spec though perhaps not the correct diameter for my needs)
It all seems fairly straightforward....which means I must be missing something.:D
Anyone done this seemingly simple job?
I replaced the reservoir tubing on the ST4s a few years ago. As long as it's specified for use with brake fluid it will be fine - expensive though. Make sure it is correct inside diameter. If it's a loose fit it will leak which you definitely don't want. Another thing I found out the hard way is that if the outside diameter is too small then the wee wire clips that secure it to the barb ends don't grip it properly. So you really want tubing with the correct inside and outside diameters.
Cheers Derek, I was just wondering if I'd missed anything obvious, the ID I'll measure against the spigots on each end(after the wider bit at the end), the OD I can get from the OE hose.
If there's any disparity in the ID's then I'll go with the smaller one with the assumption there will be enough give in the tubing to compensate for it, hopefully thats not a misplaced hope.
