Brake/Cluutch Fluid
stirrup
Been trying to find Shell Advance DOT 4 to top up my clutch res. on M695 as spec'd in the Manual. Only two Shell garages around here. Neither have it. One had Donax which (it said on the bottle exceeded DOT 4 and 5). What do you use? Have you ever found the Shell stuff thats spec'd?
(Also tried to be a good guy and use the Shell greases specified in Manual too. Never found those either. Used Rotax and good old copper grease instead)
brilliant i love bit of confusion, derek will be along shortly.
/ian
Right enough Ian.
I can confirm that Dot 3, Dot 4 and DOT 5.1 are all mineral based and can be mixed. DOT 5 is silicon and must not be mixed with any other brake fluids. It can give problems with seals as well if they are not compatible. God knows who had the daft idea of coming out with higher spec fluid and calling it DOT 5.1, it should have been DOT 6 if they had any sense.
arse i dont know how i got that wrong, its a good job we have real expirts here (i realy hope stirrup hasnt done anything bad off my 'advice' ) :o
Scotty, Main thing for me was that between brands was compatible so I'd decided to top up with any well known DOT4. So done nothing (more than usual!) daft here. Thanks to all for clearing things up, appreciate the help.
