Brake Bleeding Tools
AndySPS
Anyone recommend a brake bleeding tool . You know ...the ones with a non return valve to aid bleeding of the brakes ....ect .....
Andy
( I'll be getting charged for all this advice next!!!:o )
The one and only...MityVac :thumbs: You'll love it so much, you'll soon be invting people round to do theirs :D
At £35 it might not be the cheapest option, but well, well worth it. Bleeding brakes takes about 30 secs with it. Loads of places sell them - M&P, Demon etc
the mighty vac is good and motrax have just brought out the big bleeder which at £60 is expensive but apparantly it can be used for pressure testing systems other than brakes as well.dont bother with the little bleeder thing tho they just dont work basically,the mechanical ones seem to be much better and quicker
Found this:-
http://cgi.ebay.co.uk/EEZI-BLEED-BR...066852972QQcategoryZ30917QQrdZ1QQcmdZViewItem
Anyone any experience of it? The back brake on the 748 isn't as keen as it should be. Last year I put a new master cylinder on and it was fine and now a year on there is a lot of lever travel before the brake bites. It's Due it's MOT soon so I have to get it sorted. I did take the caliper off and split it, cleaned it up and put it back but I didn't put any grease round the piston, do you think that this is part of the problem?
The Eezi-Bleed is a great system. I've been using one on my cars for the last 20 years BUT it works by pressurising the master cylinder and the kit doesn't come with caps that will fit the reservoirs on your bike. So I wouldn't bother unless you've got some spare caps to convert. They need a hole about 8mm drilled in the centre.
i do mine backwards, attach syringe at caliper end and force fresh fluid through to the lever, use another syringe to catch the excess at lever. its how the race techs do it on DH mountain bikes where a very small amount of air can present a big problem given the volumes of brake fluid involved. the air seems to flow back up to the handlebar easier doing it that way.
