Brake Bleeding Issue
the duke
Hey everyone,
Just fitted a new thumb brake to a 1098 but having an issue bleeding. Obviously the brake line is very long (2m) so I expected a fair amount of bleeding to expel all the the air, but I can't get any back pressure on the caliper. I've tried bleeding conventionally i.e. pumping the lever and opening the bleed nipple (with a hose and non return valve). This didn't work so I caved and bought a pressure bleeder from Halfords which ported fluid from the caliper to the reservoir, but still no success. To be fair, for £20 I wasn't expecting the best bleeder in the world, but it should have been sufficient based on the size of the caliper.
I've check the master cylinder, reservoir, caliper and line for blockages but all seem good.
Anyone have any ideas?
Thanks,
Karl.
I gave up trying to bleed from the top down years ago, was always told air rises so it seems stupid to force it out at the bottom of the system. Large syringe filled with fluid attached to calliper bleed, open bleed and force fluid through to master, make sure you keep removing fluid from the master or it gets messy :) if its old ish fluid I'll usually run fluid from top first and get the darker coloured stuff out of the system then rebleed from the bottom.
