iconic944ss
Taken from another forum:
"I don't usually gush about a product, but this one I will.
Got a 2015 Multistrada and loved it except for one thing ... The bike suffered from overbearing EU rules on emissions. This causes the bike to have a very lumpy and jerky throttle at 3-4k and around 6-7k revs. This is the area the EU test the bikes at. So manufacturers program the bikes to run lean at these points. This is what gives the poor throttle response and it's where I have the revs when in town or cruising - Not good.
So did a bit of research and getting the bike dyno'ed seemed the only way to sort it, until someone mentioned the 'Booster Plug' that is.
So had a look into it. The Booster Plug (www.boosterplug.com) sits between the Air Intake Temperature sensor and the ECU. It has an external temp sensor itself so its adaptive unlike the cheap chinese crud. It basically adds a small amount of fuel when needed and sorts out the lean running. I was skeptical as usual, but I thought sod it I'll give it a go.
Well it's fitted and I've done about 70 miles of mixed roads and I'm astounded how well the plug works. Totally smooth throttle and all the slow traffic jerking and having to drop gears is gone. Its transformed the bike totally.
They do plugs for most modern bikes and they cost in the region of £125 (Currency conversion dependant). Delivery was 2 days.
No, I don't get commission and I've nothing to do with the company. Just want to pass on what i thought."
