As the title suggests... The Monster is blowing out the tail light regularly now. It was only the sidelight at 1st, but now seems to have popped the brake as well. Common fault and any suggestions? Many thanks. G
The standard tail light on my 944ss never blew a tail bulb (from my feeble memory) and yet using the same wiring, a 916 style tail piece that I bought used to blow lights, every week or so.
LED is the way forward I guess, either LED bulbs or a new unit.
As an aside I managed to remove the LED board from a Triumph 675 tail light and fit it into the back of my ST4s - worked a treat and still going strong.
Bulbs blowing frequently is for one of three reasons;
1. Vibration
Vibration is the most usual cause and can explain why Frank's 944 never blew tail light bulbs but the 916 did. Different construction of the mounting bracketry results in different harmonic frequencies. LEDs are the solution here.
2. Bad/intermittent connection
All connections should be checked particularly the bulb contacts in the holder.
3. Over voltage
As a precaution it is as well to check the battery volts with the engine running. The bulbs blowing might be a symptom of a more serious fault with the voltage regulator. Anything over 15V and you have a problem.
