Pict
This was the only way to get a good back brake on an SS when I last did it in the 90's and it still is...
Of course the wisdom of hauling the bike half to bits a couple of days before the 'Fling is questionable.. fortunately nothing sheared.
Points to note are the cunning use of a clamp turned spreader to put pressure on the pedal while you faff with the nipple. Use of a spanner (bit of wood is better) for the pads to bite on so as not to pop the pistons out and use of red elastic bands (yellow are faster... as any fule kno)
ps my fancy vacuum pump brake bleeder failed miserably as sooking air down the thread of the nipple was easier for it than drawing though fresh fluid - even after I tried grease on the thread
