monster_998
Went a run up to Arbroath last night but on the way home something bizarre, and worrying, happened.
Fired it up a McDonalds and headed towards Dundee the rev-counter started behaving very irratically, usually around 6,000 rpm, sometimes dropping as the revs actually increased, sometimes staying in the same place as the revs dropped. Putting the lights on added 2,000 rpm and the indicators flashed double speed.
I stopped in a layby outside Dundee, killed the ignition, waited a few seconds switched if back on, indicators OK, fired and up agan and everything was back to normal.
Got home without further problems.
I had an issue last year with the rev counter jumping on tick-over but the lights didn't impact it and the indicators all worked, so think this is something different.
I was thinking the voltage regulator was goosed but then everything started working again.
Any ideas/advise greatfully accepted.
