Bike won't start
Bruce
Hi All,
Ashamed to admit but I have a 900ss which I have neglected for too long. I tried to start and at first the starter button tried to turn the engine but then I believe I held the button down too long and then next time I pressed there was nothing.
All other electric components are working and all fuses appear to be fine.
I have thee battery connected to an optimate and both lights are green so I can only assume that the battery is fine and as I said above, all other electrics appear to be fine.
I doubt it is a connection as it was trying to turn the engine at first.
I have also tried to jump start the bike without success.
Would this be the starter solenoid? or does anyone have any alternative suggestions.
Thanks in advance for any help.
Bruce
Hi Bruce,
There is a fault finding chart in the back of the Haynes manual, think I have an e-copy of it on my forum which i think is in my signature block.
Could be solenoid, arcing a big screwdriver between the poles of the solenoid should prove if its that or not but can result in big sparks! Using the starter motor terminal is an option slightly further away from petrol.
Good luck.
Many thanks, I wasn't sure if I could jump start from my car without potentially causing any further damage, thanks again, Bruce
Where about in Perthshire are you? Im on holiday next week...could pop round and give you a hand if you want...
if you here a click when you push the starter button its the starter relay , if I remember correct its behind the left fairing panel below fuses or righthandside panel there are two relays together.
if it doesn't click check connection to solenoid on right under frame tube below battery.
Don'y try jumping from the car with the car engine running. The voltage spikes can damage electronic components. I know a guy who zapped both ignition modules on a 900SS by doing this. :eek:
Thanks for the offer but I just got it started by joining the two connectors on the solenoid with a screwdriver which tells me the prob is with the solenoid.
Thanks again
Bruce
Well done Bruce. I actually used a new solenoid from a 1100 Austin mini if I remember right! needs mounting 180 degrees around from the OEM unit and also needs a separate earth but was less than £10 when I bought it ;-)
