Bike lifting Assistance!
richc
The seals have gone on the Smart's front forks.
Does anyone in the Yorkshire area have a front paddock stand, the yoke lifting variety I could borrow for a week? I don't fancy shoving bits of wood under the engine!
Is re-fitting forks fairly easy, well getting them lined up squarely?
Rich
it is possible to suspend the front of the bike with a 'A' shaped step ladder if you take the tank off first
refit is all very easy :)
I use a couple of climbing straps around headstock, 2 thick ratchet tie downs strung over beam in garage connected to straps and ratchet front end up, slightly loosen front wheel, brakes but not yokes before lifting and then once up loosen yoke bolts carefully with wheel mudguard out. i then stick a motox engine stand under it and lower it to just touching just in case :) replacement is easy they slide in, set to same ring line, tighten yokes!! front wheel in and lower carefully, leave it with a little bit of tension on on strap, loosen yokes a touch and make sure its all lined up then torque.
Cheers for the info.
Not got a garage, but I do know where I can borrow an engine hoist, on its own frame, from.
Should be interesting.
Rich
