Bevell SS w. Imola cams...
Vacant Possession
Hello Summer lovers,
My cylinder heads need a shim and the easiest & quickest way for me to do this is to send of my spare heads for building, drop the engine & swap heads. My spare heads are 32mm inlet desmo heads which will be converted to 40mm, mildly gas flowed with Mille 42mm inlet valves fitted & lead free exhaust seats. The only cams I have are Imola. Well, that's not entirely true, I also have one slightly worn standard cam :).
My questions are:-
  • are the Imola cams OK with standard 86.00mm Borgo pistons?
  • how will the bike feel & run in comparison with standard?
If the answers to the question are not appealing, I can tear down my existing heads and use those cams - it just means extra time dropping the engine now.
Long time ago now, but I ran my 900ss with Imola cams and the standard 86mm pistons with no problems. As I recall they moved the powerband up the revs by about 1,000 rpm, making maximum power in excess of 8,000 rpm.
Imola Cams
Hi Paul
For normal road riding in my experience Imola cams are not at there best as Derek say's power is moved upwards and you suffer lower down but at the end of the day as you the have spare heads which your going to mod you may as well experiment.
Scott
The heads are destined for machine #3, which will probably be 'Old Green'. The bike is currently 'here and there' and my wife asked me formally to desist from further bike building until we are loaded, I have abided by this request. This might mean it stays in bits.
I have some really quite tasty bits for this bike, however as we all know the transformation from a pile of bits to a swan inevitably costs loads.
Thats it Dr D
The Imola cams come on cam at about the time the crank blows up.<8000rpm. Like all these tuning parts they were not designed to be used in a stock engine but most importantly a stock crank.
I do truly believe the SS lump is what it is and set up properly can start first go every go and run like Swiss watch. I remember 15 years ago following John Fallon from Made in italy motorcycles on my FZR1000EXUP, him on his stock black/gold SS, i could stick with him on the A roads but he left me on the B roads. I had 140bhp, he had about 65bhp. when you have something like a well set up SS more power doesn't make you much faster on the road.
I don't want to @@@@ on anyone's fireworks but if a good SS doesn't do it for you maybe you need an 888 ? its a classic in its self now and way way cheaper than tuning an SS.
Thank you Mr. Kevin Bracken...
Here is an extract from Kevin's excellent article, it is Kevin's comments on these very pistons that got me excited...
Pistons
This is the key power element in the Bevel drive engine. In December 1980 CR Axtell let us bring our near-stock Ducati in for a dyno run. My dyno run sheets showed that with 40’s, Conti’s, stock valve sizes, porting and valve job by Jim Woods and standard Nippon-Denso ignition the bike made 59.6 HP. The dyno table is shown below. The first HP column is with stock cams. Later in January of ’81 we ran the bike again, but this time with the "Imola" cams. Note that the stock cams are actually better for street riding. They are geared to the engine’s strength—torque down low. The Imola cams give less power down low and only make a really big difference at and above 8500 rpm, dangerous territory for the crankshaft. I remember quite painfully ($$$) the result of racing with consistent shifting above 8500 rpm. Usually in the next race, the crankshaft would fail, taking the pistons with it.
Code:
        Stock Cam     Imola Cam
RPM     HP            HP
4500    47.0          42.3
6000    57.3          56.0
7000    59.6          58.0
8000    55.4          54.6
8500    45.0          54.2
9000    Not run       46.6
Note: all values are corrected to standard temperature and pressure at the time of the test
After seeing the unimpressive results on the dyno, Ax took pity on me. He suggested that some good high compression pistons would do wonders. He was right. I was to find out that this was typical advice from Axtell…being right, that is. Having had many a piston made in the US, Ax was not particularly happy about their longevity and quality control. He felt that the aluminum alloys used by the American piston manufacturers were not high enough in silicon and thus too soft, leading to dimension changes under the stress of racing. Ax suggested Europe or Japan, with Cosworth as a possibility. Luckily, Cosworth had a local site in Torrance in the early 80’s. I approached them and to my amazement they were willing to make me a few (3) prototype pistons. I drew something up and Ax corrected my misconceptions. I sent the sketch to Cosworth. It was an 87 mm diameter piston that increased the displacement to 883 cc. Ax was pleased. After some nervous moments on my part wondering if they would ever get here, Jim Woods installed the pistons (see below) and we ran on the dyno again.
original Cosworth pistons Axtell helped me design.
another view Cosworth pistons
Basically, just installing those pistons yielded 80 HP. Here is the chart again with the previous numbers side by side for comparison. The Cosworth pistons were tested with the Imola cams. I think I jumped all around the shop. When I got to Willow Springs Raceway, that change was worth 4 seconds a lap.
Code:
        Stock Cam     Imola Cam     Cosworth Pistons
RPM     HP            HP            HP
4500    47.0          42.3          Not run
6000    57.3          56.0          68
7000    59.6          58.0          76.6
8000    55.4          54.6          80.2
8500    45.0          54.2          78.7
9000    Not run       46.6          72.5
Paul
I sold Kevin another set of crankcase only last month as he had knocked the bearing houses out of his old again as i understood it.
What he is doing is a no expense spared project that's been running for nearly 40 years..Every bit of his tuning is a progression, there is nothing stock left in his engines. Yes he gets a few BHP from his cams and pistons but he is using belt drive heads with larger straighter inlet tracks.
What i am trying to say is porting and mille valves will help the std pistons work efficiently, it will not be enough to help Wiseco high comps work efficiently and the minus side loading up the crank would not be worth it.
all of this is dependant on getting the whole lot set up right, its not something you can do by just swapping the head and barrels and sticking the same carbs and ignition back on the day before you want to go for a ride. By the early 80s even Ducati realised they needed a 4 valve head to get a 450cc cylinder to breath. Dont forget at the time something like a Honda 750 was only trying to breath about 185cc per pot
Paul - last year I bought a very smart 996 for £3,400. It went very fast...
I'd vote for keeping the bevels in a nice low state of tune to avoid a very expensive big bang!
Right, I have listened :) my spare heads are on their way to Jan Biggelaar in the Netherlands.
Paddy has done me a pair of crackin' standard cams amongst some other horse trading - thanks Paddy. Take a look at these! :hail:
Jan Biggelaar is fitting lead free tolerant exhaust valve seats, 42mm inlet valves, new guides, new opening & closing rockers & cam support bearings.
Andrew@Mdina has sent the valves directly to Jan Biggelaar - thanks Andrew.
In addition he is converting these 32mm inlet tract heads to 40mm, fitting the Malossi 'O' ring inlet manifolds and gas flowing the lot to make it match & flow properly.
I can hardly wait!
Hopefully the heads will be back in time for the Dales bash - if I can make it.
The old heads? They'll get 42mm inlet valves too when I can afford it, they are already gas flowed and already have the Malossi inlet manifold conversion. These heads will now find a new life on my 'special' Old Green when I have some money :scratchhead: :dunno:.
Having read all the above I probably wasted my money fitting the Imola cams and probably led to the ultimate destruction of the engine. The bike ceased to be taxed 3 or 4 years after I sold it in 1989 and has never been seen or heard of again.
I've often wondered that. If I'd kept it how much would I have spent on it over the years? More than I could afford I think :eek:
