Bevel Selector Drum Gear positions...
Vacant Possession
I haven't seen this documented anywhere else, so this seems like a good place ;).
I can't imagine why this would be useful in normal life, but here are a sequence of pictures showing the selector drum's position for each gear. It is normally invisible as it lies behind the clutch.
NB: I am starting with neutral as it occupies a special position with the marker in the vertical position.
Neutral:
First:
Second:
Third:
Fourth:
Fifth:
I hope this helps someone, believe it or not, it took me a while to work out what was going on :o.
