The first thing that comes to mind is that the drive line is on the opposite side of the bike. You would need to cut off the shock mounting lugs, turn the swing arm over and weld them on what used to be the underside of the swinging arm. Same with the chainguard mounts.239desmo said:Does anyone have any experience of fitting a belt motor in a bevel frame? Apart from mounting points, in particular I am thinking about issues getting sprockets lined up or not. Any comments appreciated.
What a load of rubbishDerek said:The first thing that comes to mind is that the drive line is on the opposite side of the bike. You would need to cut off the shock mounting lugs, turn the swing arm over and weld them on what used to be the underside of the swinging arm. Same with the chainguard mounts.
Thanks Derek! I've spent the last 24 hours thinking "could I not just turn the wheel round" but I was worried I was going to make an even bigger tw@t of myself than usual by saying so! I have the chance of a Darmah rolling chassis and that is where the idea came from. I am wanting an "old" look with modern engine. Handling is way down my list! I can't get to the limit of a 200 Yam so there is not a snowballs chance of doing so with anything bigger! Knee down etc doesn't interest me. Ideally I want a frame with a spine to fit an imola tank etc and I am reluctant to buy a perfectly good Pantah and chop it about but I may not have an option. I reckon I can build something and have change out of 3 grand and it will be a true one-off. Thanks to all so far for your input.Derek said:What a load of rubbish
You just need to put the wheel in the other way round. You'd still need to do something about the brake anchor point and chainguard mounts though.
Seems to me though that you'd be better just buying the new Sport 1000S next year. Although I supposes there's the matter of a few thousand pounds in the cost right enough.
239desmo said:Thanks Derek! I've spent the last 24 hours thinking "could I not just turn the wheel round" but I was worried I was going to make an even bigger tw@t of myself than usual by saying so! I have the chance of a Darmah rolling chassis and that is where the idea came from. I am wanting an "old" look with modern engine. Handling is way down my list! I can't get to the limit of a 200 Yam so there is not a snowballs chance of doing so with anything bigger! Knee down etc doesn't interest me. Ideally I want a frame with a spine to fit an imola tank etc and I am reluctant to buy a perfectly good Pantah and chop it about but I may not have an option. I reckon I can build something and have change out of 3 grand and it will be a true one-off. Thanks to all so far for your input.![]()
Good luck with that, sounds.....ermmm.....nasty! If it is going to improve your health then it's worth the pain and hassle in the long run. I am on holiday next week and may end up staying in Harrogate on the way back up the road, so if you could point me at any good Italian restaurants in the area that would be good. Hope all goes well meantime.steve748 said:Stewart, I knew you would be thinking along the samelines as me on this one!
I can't see it...Oh hi Stewart, that's an errrr unusual ermmmm motorsickle...... what does it say on the tank......Yamati :lol2: :lol2:
I will be offline for a while too as I have to return to hopital tomorrow to have a nerve transplanted into my arm.![]()
239desmo said:Good luck with that, sounds.....ermmm.....nasty! If it is going to improve your health then it's worth the pain and hassle in the long run. I am on holiday next week and may end up staying in Harrogate on the way back up the road, so if you could point me at any good Italian restaurants in the area that would be good. Hope all goes well meantime.
