Belt tension check
Geoff
Hi,
Here's what looks like a good tool for setting the belt tension. At over $200 might be a tad expensive unless you adjust them a lot! Unlike the proper tool which does it optically this uses harmonics which should work just as well.
http://www.motoreva.com/index1.html
Geoff
Speaking to Brian the other day when he was changing my belts and a little tip he uses is to leave the rear cylinder belt slightly looser than the front as it heats up more because of the airflow. Not so important on water cooled bikes.
I take it that's what you mean twpd?
